Re: 424 loader hydraulics
Posted by Owen Aaland on June 24, 2012 at 17:45:10 from (216.47.35.73):
In Reply to: 424 loader hydraulics posted by Chris Snow on June 24, 2012 at 11:43:03:
Your best solution may be to install a front crankshaft mounted hydraulic pump. The set up was common on the Industrial models. It uses the transmission as additional reservoir and gives you many more GPM than the regular hydraulic pump. If you use the current hydraulics for the loader it will be very slow in use.
