424 loader hydraulics
Posted by Chris Snow on June 24, 2012 at 11:43:03 from (107.8.55.95):
I have 424 gas with a freeman loader. One of the previous owners hooked it up using a prince pto pump and a auxiliary hyd tank. this set up works well but I can't borrow or rent any pto driven implements because I require a shorter pto shaft. The tractor does have power steering and 1 aux valve. How can I hook this into the existing hyd pump or can I get a front crank mount pump to run it off of. Also this tractor has a single engine driven pump could I get one of the double pumps and run it that way. thanks Chris
