Re: Farmall M Engine Identification
Posted by Andrew Z on June 25, 2012 at 06:01:02 from (64.148.21.144):
In Reply to: Farmall M Engine Identification posted by LJW on June 25, 2012 at 05:46:51:
the larger filter would indicate a early C248. Look on the front right side of the engine right above the mag / dist should be a serial number there. You can also get the part number which is behind the oil filter area as well. The dip could have been added over the years, M&W etc.
Andrew
