Re: S/A Industrial: Rear Axle Slides In and Out About 1/2...
Posted by Hendrik on June 25, 2012 at 12:48:46 from (194.53.253.51):
In Reply to: S/A Industrial: Rear Axle Slides In and Out About 1/2 Inch posted by Bruce Brittain on June 25, 2012 at 05:32:04:
Given the situation you (and the tractor) were in and your planning to tear into it further some time, you did allright. I would not be surprised if the dislocated bull gear also ate some cast iron away from the inside of the final drive casing.
You cannot reverse the bull gear since it is a-symmetric; although one could swap the left and the right bull gear which would basically reverse them. You cannot reverse the pinion since it it part of the differential shaft. I concur with Phil that you should not reverse one member of a worn in pair of gears.
So replace parts as necessary as you tear into it. Replace all seals and bearings (the bearings being standard ball bearings are relatively cheap anyway). Your old seals will be shot, especially after this spell of running with too much axial play.
Ask questions where needed!
