Re: Farmall M Engine Identification
Posted by Owen Aaland on June 25, 2012 at 21:54:24 from (216.47.35.115):
In Reply to: Farmall M Engine Identification posted by LJW on June 25, 2012 at 05:46:51:
If the dip stick just goes through a hole drilled in the block it is an aftermarket item added to the tractor. If the dip stick screws into a pipe sticking up out of the block and is marked one side for engine running and the other side engine off it most likely came out of a power unit, crawler or W series tractor.
