Re: 300 split update with more photos
Posted by charlieu on June 27, 2012 at 06:56:45 from (97.127.212.231):
In Reply to: 300 split update with more photos posted by Zachary Hoyt on June 26, 2012 at 19:15:12:
Did you check the condition of the 8 rollers for the TA? They should be nice and round, no flat spots. When you pulled the rear carrier off, the rollers are inside. They will usually fall out if you tip the carrier up on end.
