Re: New Super A clutch Problem
Posted by CNKS on June 27, 2012 at 17:28:36 from (216.144.104.128):
In Reply to: New Super A clutch Problem posted by nickc711 on June 27, 2012 at 16:07:02:
The pressure plates are supposed to be pre-adjusted. You might check and confirm that the adjustments are all the same height. Be sure the the pedal has the correct free play, about 1 inch, I don't have my manual handy. Anyway adjusting the pressure plate usually does no good as all it does is change the pedal free play, easier to adjust the pedal. Andrew is correct on the gear clash -- otherwise you have something installed wrong, or the pilot bearing is dragging. Good idea to replace the pilot and release bearings with the clutch. Be sure to lubricate the new pilot bearing as it cannot be greased from the outside.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
