New Super A clutch Problem
Posted by nickc711 on June 27, 2012 at 16:07:02 from (24.3.250.70):
I recently replaced the clutch friction plate and the pressure plate. But the clutch does not fully disengage. Should I adjust the pressure plate. My pedal throw is good? I thought the pressure plates came pre adjusted?
Thanks
