farmall H charging problem
Posted by SLH on June 28, 2012 at 14:03:59 from (70.242.134.188):
My farmall H does not charge I have done all of the checks as far as grounds and jumping ground to the field no charge when I jump from the battery terminal on the regulator to the generator terminal on the regulator I get a discharge on the amp meter I'm sure everything is grounded. also I did polerize the generator .THANKS for any help.
