Re: cleaning out bad oil, Block Update
Posted by rustred on June 29, 2012 at 07:26:17 from (184.151.222.177):
In Reply to: cleaning out bad oil, Block Update posted by BigTone on June 29, 2012 at 07:12:09:
just remove the pan and clean it good, and the proper way. just pouring stuff through it does not remove the sludge. how can you check for a leak with the pan on? the leak may only be one drop in 5 minutes.you dont want the oil pump picking up loosened sludge.
