cleaning out bad oil, Block Update
Posted by BigTone on June 29, 2012 at 07:12:09 from (166.248.0.100):
i need to clean out the bad oil/water in the block. I was told to pour some gas into the oil fill and let it work its way into the pan and it will clean all the bad oil out, is that safe? I dont want a little gas that did not drain out get mixed with the oil and do damage to the engine in the case the block is not cracked...
Im not sure if there is a crack in the block, put boiling water in there last night, let it sit, check this morning and the level did drop less than a 1/4" and there was very little in the pan making me think that some of the water from the blow out is still in there, going to put the head back on and see what happens....
