Re: cleaning out bad oil, Block Update
Posted by Bob M on June 29, 2012 at 07:48:17 from (69.207.87.163):
In Reply to: cleaning out bad oil, Block Update posted by BigTone on June 29, 2012 at 07:12:09:
Drop the pan! Can almost guarantee you will find a layer of "gunk" on the bottom that will take a putty knife to scrape out. And while the pan's down also check/clean the oil pump pickup screen.
Before sticking the pan back on repeat your boiling water block leak check.
