As Jim said and if you think about it hold old is that head gasket that blew??? All it takes is to over heat and engine one time to many and yes they will blow a head gasket. Vinegar should do the trick heat it pour it in let it cool and strain it and do it again. May take 2 or 3 time to get it all unless you want to pull it all the way apart and have the block boiled out
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
