Re: ammeter
Posted by CNKS on June 29, 2012 at 18:01:12 from (216.144.104.128):
In Reply to: ammeter posted by GordoSD on June 29, 2012 at 16:55:33:
Not normal with the charger off. Probably stuck, not too easy to replace on that model.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
