Posted by gene bender on July 02, 2012 at 10:20:46 from (67.55.226.123):
In Reply to: Super A Battery Dead posted by John Franklin on July 02, 2012 at 06:30:25:
Your SA should have a 6v pos ground regulator so if when you changed the battery and changed the ground to Neg you probably fried the reg and that could sure run the battery down. Did you clean all connections when installing the new batt
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
