I worked on a 450 a while back and had this issues as well, so I learned quite a bit. Have you hooked a gage up to the inlet hose of the PS? If not try this and look right when you start the tractor, if it goes up quickly and then backs off it is probably the auxillary check valve. On the one I worked on the spring was worn and would not put the proper pressure on the ball and let fluid pass thru. This is removed from the bottom of the block. Good Luck and let us know how it turns out!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
