Re: Farmall 656 hydraulic problems
Posted by pete 23 on July 05, 2012 at 11:31:15 from (74.32.238.2):
In Reply to: Farmall 656 hydraulic problems posted by Ryan Nagele on July 04, 2012 at 09:51:21:
Raise your hitch up, then jump up and down on it to
see if it spongy. I think you are sucking air.
Possible places, filter cover gasket first one,
second is internal return line hose in rear end,
third broken loose suction tube in rear, fourth,
suction tube seal on pump where it goes into frame
to filter . I would pull the third arm cover off
rear and inspect the hose for burst, bend or off and
grab hold of suction tube below oil level to see if
it is flopping around.
