Farmall 656 hydraulic problems
Posted by Ryan Nagele on July 04, 2012 at 09:51:21 from (98.132.211.244):
I have a Farmall 656 that has hydraulic problems all the way around. (Manual Trans) You can turn and turn the steering wheel and finally the wheels will turn sporadically. When idling the the remote with no cylinder hooked up will kill the tractor then the next time it will not effect the engine at all. the 3 pt arms go down and with come up in a jerking motion some times taking 2 minutes. I wondering if my problem is the pump or the flow divider valve? I do not have a flow meter to measure the pump flow. Any Ideas?
Thank You
Ryan Nagele
