Danuser 2 point blade question
Posted by D Slater on July 05, 2012 at 18:33:42 from (184.15.36.245):
Picked up this blade that set around and the joints were stiff. Have everything freed up exept maybe the tilt. I'm not sure how the lock is made and don't want to force things and mess up. Looks like the big wing nut loosens up to move the tilt. Does it just loosen, or need to come out so much? How does things lockup inside the frame? Looks like a Danuser model IB. Thanks to anyone who knows.
