Re: Danuser 2 point blade question
Posted by farmallhal on July 07, 2012 at 08:17:49 from (76.4.182.194):
In Reply to: Danuser 2 point blade question posted by D Slater on July 05, 2012 at 18:33:42:
Here are the adjustment instructions from the Danuser Form No. 1402 for the model IB All Purpose Blade for the Fast Hitch International tractors:
"Any desired tilt of the blade to the right or left may be obtained by the following procedure. Loosen wing nut approx. three turns, pull the blade frame slightly rearward to disengage clutch teeth. Rotate blade frame to the desired position and tighten wing nut. Caution: Be sure clutch teeth are completely engaged before tightening wing nut."
The blade frame according to the pictures is that portion of the blade to the rear and not the fast hitch yoke which is in front. There must be some type of splined components inside the frame which must be engaged to maintain the set position. It also states to check the wing nut for tightness after the first hour following adjustment.
Hope this helps and I sent an email as well, Hal.
