Re: Hello, first post
Posted by D Slater on July 06, 2012 at 04:27:32 from (184.15.36.245):
In Reply to: Re: Hello, first post posted by Patrick HMD on July 05, 2012 at 21:51:37:
Venturi will only fit correct one way. If I understand the description correct, venturi is installed correct. They stick inside the throttle body sometimes. On realy stuck ones I remove the throttle shaft and drive them out the bottom of the throttle body. Old wood broom handle sawed off with a rounded end to venturi works good to do it without damage. Don't know if this is the reason for the float damage, but thats something that can happen if a air hose is used to blow through the carb inlet for a fuel flow problem by someone uninformed. Or float was rubbing the bowl and they just mashed it in to clear instead of doing it right.
Front bolster is the reason for the hood being to short. It moves the radiator around 1.5 inches farther forward or away from the engine than a M gas bolster.
