Re: Hello, first post
Posted by rustyfarmall on July 06, 2012 at 08:04:10 from (67.55.162.174):
In Reply to: Hello, first post posted by D Slater on July 06, 2012 at 04:27:32:
Exactly! The venturi cannot be installed wrong without first breaking something. If it is stuck, and most of them are, I use a small propane torch to heat the cast iron around the venturi. Get it good and hot, and then squirt some penetrating oil on it. Squirt a little at a time until it stops smoking, and then just walk away from it. Go have a cup od coffee or whatever, and then carefully grab the venturi with a pair of pliers and gently try to turn it, nice and slow, back and forth, squirt some more oil, use some patience, and eventually it will come out.
