Re: M carb float and needle valve problems
Posted by rustyfarmall on July 06, 2012 at 11:08:59 from (67.55.162.174):
In Reply to: M carb float and needle valve problems posted by Marty from MN on July 06, 2012 at 10:12:24:
Take a good look at the float bracket. Notice how one leg is slotted and the other leg has just a hole? Have you taken the time to try and understand why that one leg is slotted?
I'll give you a hint. The slot is there so it can be squeezed together just a wee bit and make that float hinge pin fit TIGHT. The slot needs to be squeezed enough so that you need to work to get the hinge pin in place.
There is NOTHING else to keep that hinge pin in place. If it DOES NOT fit TIGHT, it WILL fall out.
