Re: Farmall 450 Gas timing question.
Posted by Bob M on July 06, 2012 at 14:27:16 from (69.207.87.163):
In Reply to: Farmall 450 Gas timing question. posted by Tony_Idaho on July 06, 2012 at 13:54:52:
Tony - Timing notch "dancing" a half inch around the pointer is a bit excessive. The most likely cause is worn distributor shaft bushings.
Remove the rotor button and check the shaft for radial runout (side to side play). If the runout's more than a couple thousandths it's time to rebush the distributor.
A busted cam gear hub can cause timing variations too. But this is usually accompanied by general poor running; also sometimes by an ominous knock from the right front of the engine.
