Re: Farmall 656 hydraulic problems
Posted by pete 23 on July 06, 2012 at 21:32:01 from (74.32.238.2):
In Reply to: Re: Farmall 656 hydraulic problems posted by Ryan Nagele on July 05, 2012 at 21:06:49:
The two pumps are mounted piggy back and draw oil
from same source and the main large suction tube
in rear draws from bottom of case. However, that
hose coming down from the top goes right back into
that suction tube also as it is return oil from
valves. It's purpose is to reduce cavitation, in
other words , makes it easier for pumps to pull
oil from rear frame. Any leaks in hose or
looseness of pipe hose is connected to on top will
cause air suction leaks.I should have mentioned
also that there is an o-ring between trans
housings where suction tube goes through and it
can leak also.
