Re: Farmall 656 hydraulic problems
Posted by Ryan Nagele on July 05, 2012 at 21:06:49 from (98.132.211.244):
In Reply to: Farmall 656 hydraulic problems posted by Ryan Nagele on July 04, 2012 at 09:51:21:
I removed the third arm inspection plate. Does that suction tube feed both pumps? If so does that tube suck from the bottom of the case?.
Thanks again.
