Re: leaking Injectors Super MTA
Posted by sflem849 on July 07, 2012 at 15:17:28 from (69.197.84.39):
In Reply to: leaking Injectors Super MTA posted by Grademan 31 on July 07, 2012 at 11:08:45:
Here is a picture of my puller at work. This puller was a failure, I ended up building a plate to use a purchased slide hammer. The plate was thick steel with two properly spaced holes and a couple nuts welded to it to accept the slide hammer. It worked in the end.
third party image
Also, take a look at your parts manual. You will see what you are after and where all the different seals are.
This post was edited by sflem849 at 15:18:22 07/07/12.
