Re: leaking Injectors Super MTA
Posted by plow hand on July 07, 2012 at 17:33:00 from (67.6.90.231):
In Reply to: Re: leaking Injectors Super MTA posted by sflem849 on July 07, 2012 at 15:17:28:
If I remember correctly I used the threaded holes as
pushers.I put a piece of steel under threaded holes
and used bolts to push out injectors..The bolts may
get damaged when used as pushers,so take a small
grinder and grind them flush when you get injectors
out.
