Re: Broken camshaft gear (crankshaft timing)
Posted by Mark Alayne on July 08, 2012 at 08:38:43 from (97.73.64.155):
In Reply to: Broken camshaft gear (crankshaft timing) posted by Mark Alayne on July 08, 2012 at 07:40:25:
Thank you all. Sounds like tearing it down is certain. I will check for the loose gear first. Also sounds like it would be better to not rotate any more than to find TDC for fear of more damage. Does the bolster unbolt separately? Or do I have to remove the front end. I have a Schwartz wide front end. I can't find any info about removing the bolster. I have had the radiator etc. off to repack before.
