Broken camshaft gear (crankshaft timing)
Posted by Mark Alayne on July 08, 2012 at 07:40:25 from (97.73.64.155):
I posted about my Super M quitting and not starting again. (titled: crankshaft timing) Several of you indicated a camshaft gear issue. Nut backing off, broken gear, or key way problem. After reading my manual I see that the camshaft gear drives the distributor drive gear. My rotor turns "normally" when cranking engine. Does this still indicate I have a broken camshaft gear? I still have a thunk coming from the engine somewhere while doing this. Any more ideas about what is going on? Since it has cooled down here in Kansas I will pull the dist./hyd pump unit once I get it into the barn. I saw a post about feeling looseness on the gear from in there. Thank you in advance.
