Re: Farmall A idle miss
Posted by kopeck on July 08, 2012 at 11:46:25 from (69.50.51.226):
In Reply to: Farmall A idle miss posted by kopeck on July 07, 2012 at 12:48:09:
I had just a minute to play with it today. All 4 plugs has some effect when they were unplugged but #1 was noticeably less effected. So it looks like something fishy is going on with #1.
I did have the plugs out a few days ago (wouldn't start, pretty sure dad flooded it) and I did notice anything way off while they were out but I'm running Autolites and the black base can be hard to read.
I'm kind of guessing it might be a valve that's not set right at this point, I mean minus a cracked ring or something like that I don't see what else would isolate one cylinder. I know it still could be a plug but I did change them all out and it ran exactly the same afterwards.
K
