So take the #1 plug and change with #2 then see if #2 has the miss wouldnt be the first time to have a bad new plug. If #1 still has a miss replace the wire. Are you using a Mag or a Dist? Bad bushings in a dist will make an engine run funny. I hook a timing lite to each wire and watch the fire can find bad wires easy or a bad worn dist by just observing the fire. I work on these engine a lot and thats just another method of troubleshooting i have learned. What kind of reading do you get with a compression tester no tricks just want similar readings on all cycls.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
