Re: 460 starting problems
Posted by El Toro on July 09, 2012 at 04:18:02 from (108.3.148.85):
In Reply to: 460 starting problems posted by reddog300 on July 08, 2012 at 20:39:14:
Since it will start while holding the starter button I think you have a defective ballast resistor between your ignition switch and the coil. You should also have battery voltage on the terminal on your ignition switch that feeds voltage to your coil. Use a volt metter and check for battery voltage when the switch is in the on position. If there's no voltage on that terminal to your coil you need to check your switch to see if voltage is being fed to your switch. If there's voltage being fed to the switch you probably have a defective switch. Hal
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
