460 starting problems
Posted by reddog300 on July 08, 2012 at 20:39:14 from (207.179.91.3):
I have replaced the battery & coil in my 460 with a new battery/coil unit because it would start than stall when I let go of the start button. It worked the first time just fine of course I charged the battery up before restarting. Then did some light work with it for about an hour and turned it off. 3 or so hours latter I try to turn it back on and nothing. The battery metered only about 10.3 volts so I charged it again, and it started and I put her in the barn for the night. This tractor has a -GND 12 volt battery and a genorator. On our 300 which is +GND 6v with genorator we have to repolorize the genorator every now and then when working on the electrical.
Do I need to do this for the 460 as well? It's not in the 460 manuel but is in the 300 manuel, will I damage any thing if I do polorize? and if I do polorize what do I jumper to where?
