Posted by mkirsch on July 09, 2012 at 06:29:22 from (64.80.110.75):
In Reply to: 460 starting problems posted by reddog300 on July 08, 2012 at 20:39:14:
Unless this is a really tiny battery, ONE hour of running would not drain it down to 10.3 Volts. We've run tractors for 2-3 entire DAYS just on the battery.
Even leaving the ignition key on for another 3 hours would not drain it that far.
You've got a MAJOR drain on the battery somewhere, or a faulty battery.
Unhook the battery, charge it up, and leave it sit disconnected overnight. Measure the voltage the next morning.
As it is, I would leave the battery unhooked when you're not using the tractor until you find the problem because you have a MAJOR draw, probably a short circuit. Could be a risk of fire there if you've got oil/gas leaks.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
