Re: Cub Cadet 100 - New Owner with PTO Clutch Problems
Posted by dhermesc on July 09, 2012 at 08:22:41 from (24.248.193.103):
In Reply to: Re: Cub Cadet 100 - New Owner with PTO Clutch Problems posted by rhouston on July 09, 2012 at 05:51:53:
Agreed.
You'll want to make sure the belt is on the both pulleys and not twisted before you tighten it up to much. If it got too loose it might have jumped off the pulley and is jammed between the pulley hanger and the pulley.
Without the PTO engaged the deck blades should turn fairly easily. If not you might want to drop the deck and make sure you don't have something wound around the mandrels. If they are clear and the belt is on straight and are still stiff (probably from rust) I'd run it for a short time, grease it, run it some more and grease it some more.
