Started H tonite...went crazy (the tractor that is)
Posted by BruceS. on July 11, 2012 at 19:03:55 from (76.15.9.253):
Finally started H tonite....new aftermarket gas line leaks at both ends.....had throttle handle set just slightly above idle.....finally started and ran wide, wide open...fortunately was able to shut down by grounding mag with a wire I had attached to it. Throttle handle goes past notches at the idle end, but will only go about half way up notch travel. I'm stuck on this one. Don't know how to adjust and have no knowledge of governors. Any ideas welcome. Will not (obviously) be running tractor until this is solved.
