Super A: How to reduce slop in steering?
Posted by Bruce Brittain on July 13, 2012 at 04:09:06 from (4.157.8.67):
There is way too much slop in the steering of my Super A. I have tightened up the tie-rod ends, and the steering column does not crank in and out when it turns, so I suspect that the problem is slop in the worm and sector gears, rather than end-play in the steering column bearings.
Is there any way to reduce the amount of slop? I can't find anything in the shop and owner's manuals indicating how to do this. Will I have to replace the worm and/or sector with new components? The sector is brass, so I suspect that that is where most of the wear has occurred. If I replace the sector, should I replace the worm, too? (Replacing both mating gears generally seems like a good idea, but it appears that to replace the worm I would have to replace the whole steering column, which won't be cheap...)
Thanks in advance.
--Bruce
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
