Easy way is jack the front up so both wheels are free. Then start ant each wheel moving it back and forth as you can tighten the tierod ends. Then the arm off the bottom of the steering sector check it for play then you need to get into the sector itself. There are bushings a bearing and the keyway on the gear. but they can be restored and will steer like new. While its jacked up grease the spindles as you do need some grease at the bottom of the spindles and with the wt off them grease should flow toward the bottom.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
