Re: carb leaking
Posted by wisbaker on July 14, 2012 at 13:48:25 from (207.118.146.19):
In Reply to: carb leaking posted by BigTone on July 14, 2012 at 13:41:25:
I don't think your choke is a factor. Your needle valve is bad or the float is stuck or full of gasoline.
