carb leaking
Posted by BigTone on July 14, 2012 at 13:41:25 from (166.248.0.64):
I replaced the head gasket, put the tractor back together, did a valve adjustment, and I must have left the choke wide open because when i turned on the gas is started pouring out of the carb between the time i went inside for the battery and came back out. I turned off the gas, and the gas finally stopped dripping but now when i turn the gas on I have a drip from the very bottem of the carb (original M carb im pretty sure) any ideas?
