C Differential Bearing Preload
Posted by TMatt on July 15, 2012 at 09:16:19 from (72.8.244.148):
I've been going through the transmission and differential of my C and replaced the differential bearings. I put it back together with the original shims and it's pretty tight. Should new roller bearings be preloaded? Is there a spec? Couldn't find much in my manual.
Thanks
