Re: C Differential Bearing Preload
Posted by Allan In NE on July 15, 2012 at 09:47:46 from (148.66.98.174):
In Reply to: C Differential Bearing Preload posted by TMatt on July 15, 2012 at 09:16:19:
You did it right
All roller bearings have to be preloaded. If the carrier was 'tight' going in, you're good. They can stand WAY more preload than 'loose'. :>)
Did you end up with good backlash?
Allan
