Re: Update on racing H
Posted by rustred on July 15, 2012 at 10:50:22 from (184.151.222.96):
In Reply to: Update on racing H posted by BruceS. on July 15, 2012 at 10:27:44:
disconnect linkage so you can hold throttle closed while running. if it slows down you have other problems down line. if it makes no diff. i would be checking throttle plate to see if its closing correctly.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
