Bearing removal
Posted by Bill in il on July 15, 2012 at 20:01:16 from (216.24.116.183):
I have been busy tearing into my farmall 400 to fix the torque. While I was in there I found the pto gears were in bad shape. I need to remove the bearings from the live pto input shaft. Can these be removed and reused or do I need to order new bearings too? Is this where you use those fancy split bearing pullers?
I need to replace the throw out bearings for the main clutch and the TA but how do you get those bearings off the carriers?
