Re: Bearing removal
Posted by pete 23 on July 15, 2012 at 20:50:51 from (74.32.238.2):
In Reply to: Bearing removal posted by Bill in il on July 15, 2012 at 20:01:16:
Those bearings are usually not all that tight. A thin (old worn out screw driver) driven between gear and brg will usually get them started off. If they are smooth and tight can be reused. Far as throw out bearing, just a rap with a hammer will knock it off the carrier. Inspect carrier where bearing rides on as they often wear a groove where it does not belong.
