Re: 400 valve adjustment
Posted by pete 23 on July 16, 2012 at 10:14:14 from (74.32.238.2):
In Reply to: 400 valve adjustment posted by ajdeereman on July 16, 2012 at 08:19:25:
In case your finger and arm isn't long enough to feel compression on number one cyl, all you need to do to determine if number one is on comp stroke is to watch the mate cyl, which is number four. Turn engine until exhaust valve just finishs closing and intake is starting to open on number four cyl. Then you are very near top dead center. Adjust number one, turn half turn until number two valves are in that rocked position and adjust number 3 cyl. then half to four and half to two. All engines run in mate cyl configurations following the firing order. Just write the half the firing order down, then write the other half right below it and you have the mate cyls.
