Re: 400 valve adjustment
Posted by sflem849 on July 16, 2012 at 12:01:27 from (69.197.84.39):
In Reply to: 400 valve adjustment posted by pete 23 on July 16, 2012 at 10:14:14:
Couldn't you use that method to do a bunch of valves at one time? I know when we adjusted the pulling tractor you can do valves 1,2,4,5 etc. Then turn a half turn and do all the ones you skipped. I would guess this is because even if those cyls aren't at TDC the cam isn't pushing the valves at all???
