Stumble at full throttle
Posted by shawnm on July 17, 2012 at 09:08:04 from (24.138.42.241):
I'm trying to get a bit of a stumble out of my 340. At full throttle it has a miss to it every now and then. Maybe its normal for these old tractors?
Last year at my local pulls it fell flat on its face. It appeared to be a fueling issue but I ended up finding an broken spring in the dist.
Here is what I've done to it this year:
- New Zenith carb
- New points (gapped to .020")
- New condenser, rotor button, cap, Auto Lite plugs, wires.
- New fuel line
- New sediment bowl assembly
- Compression is 170, 180, 175, 160
- Valves adjusted to spec
What else can I check? Here is a video of it running. At 1:40 you can hear the stumble.
http://youtu.be/PQNsrn1myMk?hd=1
This post was edited by shawnm at 09:09:42 07/17/12 2 times.
