Four hours to disassemble?? Mine are totally taken apart. Front bolster taken off, wheels off the bolster and disassembled, clutch and brake pedals removed, covers over brakes, engine is removed and stripped of governor, carb, distributer, water pump, oil canister and base, radiator and outlets, hyd pump and tubes -- block, head, and valve cover painted separately. Starter, generator and bracket. Wheel weights are off. Steering wheel, shaft and vertical rod, light bar, lights, ammeter box. Gear shift lever, belt pulley. Seat, box it sits on, seat spring and shock absorber. The PTO can be painted mounted because everything can be accessed. The only other exception is the rear wheels, painted while on because of weight. Rims are off. Anything that can be unbolted I remove. I'm sure I missed something in this list but it is removed also. That is the ONLY way to get uniform coverage on the whole tractor with zero missed places anywhere.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
